Blocking certain numbers from leaving voicemails
er051
Is it possible to block specific numbers from leaving voicemails? My child has a smart watch which rings me if they hit the SOS button. If I don’t answer it automatically then starts to ring my partner. However, the feature doesn’t divert to my partner if my voicemail is enabled. I would therefore like to disable the voicemail feature for calls from the number. Any ideas? Thanks.
You cannot configure voicemail to behave differently, based on the number calling. There are numerous ways to disable message deposit, but these will apply to all callers indiscriminately.
