17-01-2024 10:29 PM
I have a Samsung Galaxy 8. Sim 1 is EE and another country sim is in slot 2. EE is set as default for calls, texts and data. Both sims were working fine for 5 years. Several days ago sim2 stopped working. And it isn't recognised anymore.
What do you think?
Thank you,
Elena
18-01-2024 08:41 AM - edited 18-01-2024 08:42 AM
Does the SIM work if you put in the other SIM slot, @elenatoo?
18-01-2024 08:56 AM
No. I tried also another phone. And it does not work.
18-01-2024 09:27 AM
Hi @elenatoo,
That confirms that the issue is SIM card or account related. Please contact your service provider for support.
19-01-2024 10:48 AM
I contacted the Russian Vimpelcom (Beeline) (the provider for SIM 2). They tested the SIM card 2 remotely again and found out that the plastic of the card was damaged. In the end, they installed an E-SIM on my phone with the same number. Everything works now!
Thank you for the discussions regarding my problem and prompt answers))
Elena
19-01-2024 11:03 AM
