new to EE , now i have weak phone signal and mobile data is very slow
Yoshii
Hi
I am new to EE and the new 5g sim card is giving me problems. Downstairs the phone signal is very weak and the data is just as bad. I have to travel upstairs to get a better phone and data signal
What can I do?
It is a new 2 yr contract and not sure if i have 14 days cooling off rights as this was bought instore
13 REPLIES 13
@Yoshii      No network will guarantee a signal indoors and this can not get you out of a contract.   But what’s the signal like outside?
@Yoshii Have you checked the Network Status Checker there and reported your problem via that link?
You have no statutory 14-day cooling-off period if you bought from an EE Store. Other retailers are more likely to have a more flexible returns policy.
Are you able to make & receive calls OK? The signal bars on your phone screen are only a rough indicator of service, WiFi-calling is a good solution anywhere you have indoor coverage problems.
@XRaySpeX    If that signal isn’t good enough outside the property then @Yoshii does have the right to return the device and terminate the contract.
Yes, @Chris_B , but that's not the 14-day cooling-off period but the inalienable right to return faulty goods under the Consumer Rights Act. I never said or implied anything to deprive the OP of his statutory Consumer Rights. He solely asked about the 14-day cooling-off period to which I replied.
@XRaySpeX  But seeing as I was trying to find out what that signal was like outside to give the correct answer and then to inform @Yoshii  that the 14 day cooling of period doesn’t matter and is totally irrelevant to this as it’s a network issue and under the T&Cs the contract can be terminated if that network signal is none usable outside.   But I never got the chance to even explain that.     Thanks
@Chris_B : Then take it up with the OP not me. I can't help it that the OP is not answering you. Basically it was needless for Post 5 to tag me.
James_B
EE Community Manager
Hi @Yoshii,
I'm sorry to hear you're having signal issues in some parts of your home. Do you have access to WiFi at home?
Outside its better but no 5g in my area, 3 and Smarty networks are rubbish in my area too. Sky mobile is better than signal I have now.
Grateful that i can call via wifi calling but i need both
