Wifi Calling Stopped Working (31st)
Prozmonkey
Good Evening
Has anyone else's WiFi Calling suddenly stopped working today ?? (31st)
I've tried all the usual fixes. Restarted everything. Everything up to date. But still won't connect.
Kind of stuck without it as no signal whatsoever without it.
521 REPLIES 521
pcgtron
Down in Bedfordshire still as of 1634. Still no response and finding it a total pain in the ass.
I'm on Android so it's not the OS.
jyeatesx2
Mine has gone off too.  Tried all usual resets.  Still Not working  😞
Yep, definitely an EE problem, not any OS etc!
Prozmonkey
Mine just came back on. On Android.
deecee22
Yes mine went down yesterday. No information sent out so called EE. They know there is an issue but say they 'dont have the means to contact customers'!
Like you I have no connection in my home without this and no idea when this will be addressed.
Swaterworth
Yes it’s such a pain.  Where I live in Kent there is no EE telephone signal so am missing vital phone calls as I rely 100% on EE WiFi calling.   Surely EE could have emailed their customers as it seems to be a major issue.
I hope they fix it soon.
Does anyone know if there is anything you can buy to increase the EE telephone signal reception for your house.   Something to increase the signal . I don’t mean a WiFi signal, I mean just the telephone signal. I have less than 1 bar telephone reception
Mjh31
Mine has, today 1st August.. or rather that’s when I noticed. I also have done all the usual things to no avail. Very frustrating as there is zero signal here too..
Hi Swaterworth
You can buy 'repeaters' but it's not something I've used personally.
Check out  Using a repeater to improve your indoor mobile phone signal - Ofcom
Thanks.
