01-01-2024 03:21 PM
WiFi calling is available on my Moto g8 Plus, but not on my wife's Moto g9 Plus. We're both on PAYG, but I have a Subscription Pack. Is that why, or is it to do with phone models?
Thanks and Happy New Year
01-01-2024 04:11 PM
If the g9 is capable of "WiFi Calling" then there will be an option to enable "WiFi Calling" in "Settings"?
01-01-2024 07:00 PM
According to Motorola/Lenovo, WiFi calling is available on the Moto g9 Plus, but is 'carrier dependent', so the problem seems to be that EE haven't enabled it, which is a bit crap, really.
01-01-2024 07:30 PM
Checked on EE website it states: “WiFi Calling is available to anyone with EE who has a compatible device.” See https://ee.co.uk/help/mobile/manage-use/using-phone-features/use-wifi-calling#article-mobile-2
Have you checked the settings on the g9? There should be one to switch WiFi calling on/off.
01-01-2024 08:10 PM
Thanks, Storm500.
The EE list of Motorola phones is very short - just 5 of them - and doesn't include the g9 (although my g8, an earlier model is included). Strange when the phone itself is WiFi calling enabled. This from Motorola/Lenovo:
Moto G9 Plus does support WiFi calls. However, your network provider has to both offer WiFi calls and support it for your specific model in order for it to work. All of our more recent phones released in the UK offer WiFi calling, but unfortunately that doesn't mean that the networks supports the option for all of them.
It's a pity because EE had the best coverage round here, but the signal is weak to non-existent, although I can sometimes pick it up on my g8.
I'm wondering if I get a SIM from another supplier that does support WiFi calling on the Moto g9 and put it in the second SIM slot, I might have more success.
01-01-2024 08:15 PM - edited 01-01-2024 08:21 PM
Have you checked the WiFi calling settings on the g9?
Edit: I just checked if my iPhone is listed. It’s not but WiFi Calling works.
01-01-2024 08:21 PM
Yes. On my g8 they are in Settings>Mobile network>Advanced.
On the g9, they don't exist
01-01-2024 08:25 PM
Try swapping your SIM over to the g9 and see if the settings appear.
01-01-2024 08:29 PM
Good idea. I'll give it a try. Thanks
01-01-2024 08:32 PM
You could also check that g9’s OS is up to date.
