WiFi calling
Kaywivane
My Nokia G21 has a button for EE WiFi calling, but is not working. I assumed you just press the button on and hey presto but nothing. Am I doing It right? Are there other instructions? Do I need to purchase an add on to get it to work?
Thankyou
10 REPLIES 10
Mustrum
@Kaywivane   there are more detailed instructions here:
https://nokiapoweruser.com/how-to-enable-use-disable-wi-fi-calling-on-smartphones/#:~:text=Enable%20...
Are you connected to WiFi?
Thankyou, yes I am connected to WiFi.
WiFi-calling should now be standard, if the phone has a working WiFi connection with the facility enabled and is in too poor coverage for calls to work - it should enable by default.
Was the phone purchased from EE directly, or obtained SIM-free? Your reference to it having a button for EE calling is intriguing.
The phone was not purchased from EE, and it is SIM free.
Thankyou.
James_B
EE Community Manager
Hi @Kaywivane,
If you activate airplane mode then separately reactivate WiFi, do you see a WiFi Calling indicator in your status bar?
I did as you said and the indicator was an airplane✈️
James_B
Was there also a WiFi Calling indicator, @Kaywivane?
Does it allow you to make a call?
Did you follow the user guide @Mustrum shared to make sure it is activated?
This is the only WiFi calling button on my phone. I have tried all suggestions so but will keep trying. If I cannot get It to work, someone suggested , not on here, that I just use Google Meet instead which does work for me.
Thankyou for your help. 
James_B
That's the correct setting to activate @Kaywivane
Did you try making a call with airplane mode on, after activating WiFi?
