Not registered on network
letitia2
If your mobile does not work yet all the advice on here points you in a direction to call? Going around i circles here.
Mobile was working for calls yesterday. Today stats no network registered. Can any one advise?
I read info about using 4G calling of which this mobile is set up for and 5G however i still can not call.
Many thanks in advance 🙂
letitia2
Same problem. Very frustrating.
Christopher_G
Hi @letitia2
Have you tried restarting your phone? Could you pop your postcode into our coverage checker and hit 'check status' please? It should let you know if we're aware of any problems in your area.
Where does your phone state "no network registered"?
Assuming you have already tried restarting it, and that this is in a location you've previously had coverage, there may be a local outage - you can use the "check status" option on https://coverage.ee.co.uk/coverage/ee in the first instance.
