volte
Heather1984
so i upgraded my phone today to the s25 edge but there is no option for volte calling ? iv done the normal network settings etc tried and restarted the phone and still nothing is this now not an option with new phones or does anyone know how to turn it on
The recent OneUI 7 update has made it and the Wi-Fi Calling symbol among others disappear from the top of the screen under normal use (likely for a cleaner/more simplified look) even when it is active, but it should appear when pulling down the notification shade/Quick Settings from the top of the screen.
Images attached below to show the difference:
Appearance under normal use:
Appearance when in notifications/quick settings:
Most recent Android SW releases don't give a toggle switch for VoLTE, it's on by default.
Try using mobile data whilst on a voice call, without using WiFi.
hi thanks if i turn off wifi like for a few seconds i see the volte symbol on the notifcations bit then it just goes to 4g but there is no option to actualy turn it on so i assume it is on just as you say by default and dosnt come up volte ?
Most likely - are you able to use mobile data whilst on calls?
yes it does thank you
