Voicemail dusabled?
Betty777
I've recently had a prompt to restart my phone due to updates from EE and now my voicemail isn't working.
I've checked my settings and they seem to be OK. Any suggestions? Thanks in advance
Northerner
Hi @Betty777
Can you turn off voicemail by texting VM OFF to 150. If that works then try VM ON to 150.
https://ee.co.uk/help/mobile/manage-use/using-phone-features/use-voicemail
Northerner
Hi @Betty777
In what way is your voicemail not working - can you not call it? Or are missed calls not reaching your voicemail? The latter should be resolved by Notherner's advice, but the former not necessarily so.
What specific settings have you checked?
Thanks so much- voicemail is working again 😊
Hi, thanks for replying.
My phone was just ringing out and voicemail wasn't kicking in.
Northerners advice worked 😊
Leanne_T
Great news @Betty777
Really pleased you got the help you needed and voicemail is now working for you.
Have a lovely day 🙂
