22-08-2023 11:22 AM
The signal checker shows no problems in the areas I've checked but my signal is still rubbish. Should be good signal inside and out but most of the time I have no signal inside and barely anything outside, mobile data is pretty much useless, why has the coverage got so bad over the last 2 years? When I changed to EE I could use my phone everywhere I went, nowI'm really struggling .
22-08-2023 02:10 PM
Welcome to the community.
When you searched for issues in your area on the coverage checker, and it didn't find any, it should have given you the option to report a problem. If you follow that option, our network team will be able to look into the performance of the network in your area.
22-08-2023 02:22 PM
@sammiefritchley If this is everywhere you go then the issue is probably with the device not the network. What device is it ?
22-08-2023 03:17 PM
Differences in indicated coverage are not necessarily an issue unless they cause problems with use of your phone - is this so?
Sudden "step changes" in coverage can often be attributed to a fault scenario which should be visible via the "check status" option. Gradual changes over time may be due to optimisation activity which are intended to produce a better overall experience. I'm not sure from your post, which scenario you're reporting.
