13-11-2024 05:57 PM
I'm with EE, and get a fine connection on phones via broadband wifi. But our smart meter is dumb because we live in a poor network area.
Octopus say "Unfortunately, smart meters typically connect through the DCC (Data Communications Company) network, which relies on mobile signals. If you're in an area with no mobile signal, it can indeed be challenging for the smart meter to communicate effectively. However, I appreciate your suggestion about using your EE network over Wi-Fi. Currently, smart meters are not designed to connect via Wi-Fi, but I can see how that would be a great solution."
I used to have a 3g booster/signal box but gather these have been discontinued since 4g. Can anyone suggest a hardware or software solution that can offer a decent signal to our dumb meter to make it smart?
Cheers -- Paddy in rural Wales
07-09-2025 10:56 AM
Hi.
Did you get an Octopus Home Mini or find a solution to your smart meter problem in the end?
Thanks, Matt.
07-09-2025 02:20 PM
24-10-2025 12:52 PM
24-11-2025 09:46 AM
Lack of joined up thinking. There is a 'Universal Service' initiative for Rural Areas to have 'High Speed Broadband ' and Digital phone lines but none for mobile data signal. At the same time there is a push for 'Smart Meters' (Absolutely necessary if one is solar generating, also a Rural Initiative off Mains Gas) but they rely on a non existent Data Signal (We are about 5miles from UKs eighth largest Urban Metropolitan population) where they are digging up the village for Optical Cable to which the meters won't connect. It was the same story with Outreach Pop-up Post Offices where the secure communications contact was given to Verison, a US mobile company with Europe HQ in Slovenia, needless to say they had to adapt to a wire system.
18-06-2026 03:35 PM
Holy thread revival batman!
Looks like a solution to securely delivery smart meter telemetry to your supplier using your own broadband is on the way. Hopefully suppliers will be open to enabling this.
