Re: Phone is no longer connected to network
Orin21
I’m having this same issue
Orin21
I’m having this error right now my sim isn’t receiving texts or calls and next to mobile data it just says error any solutions to fix this?
Jon_K
Former EE Employee
Hi @Orin21
Are you in the UK?
What phone are you using?
Have you tried restarting your phone?
Jon
Katie_J
Hello @Orin21.
@Jon_K has just replied to your other post HERE.
Katie 🙂
Yes UK based
iphone 12
tried everything mate network settings reset, forced restart and sim removal plus some others
Jon_K
Former EE Employee
Thanks @Orin21
Can you try your SIM card in another phone to see if it works?
This would help to determine if the problem is with the phone or the SIM.
Jon
