Roaming doesn’t work (not able to connect to local network provider)
cyteh84
I’m on holidays in Malaysia at the moment but my SIM is not able to connect to local network provider. It used to connect to local network provider and will send me text explaining the roaming charges but it doesn’t do that anymore…
there are 2 potential issues that I can think of causing that.
1. I forget to pay the bill and I’m late for 1 week. I have since settle the bill. So I’m wonder my account been locked or suspended?
2. I added an eSIM from Airalo so I have internet access in Malaysia
Anyone able to help to diagnose this? I wont able to call EE. Is there an online chat? I’m pay monthly user, last connect to UK network should be 24/01/2025
Thanks,
Chee Yong
As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
cyteh84
No, I didn’t activate roaming before I leave UK as I don’t I need to receive text on my UK number…that’s why I use  Airola for data only in Malaysia. I will give them a call using Skype. Thanks
Well, you must want to connect to local network provider for some reason. Else what's the point?
If you've roamed previously on this SIM, then unless you've specifically asked to remove roaming from it - it should still be active.
Adding an eSIM to your phone should have no effect on any existing SIM (e or p) on your phone, beyond having to select which SIM is "primary" for voice, text & data.
Have you tried manually selecting each local Malaysian network in turn?
