11-04-2024 09:14 AM
Hi, I can't make any calls, it says emergency calls only, I keep switching off my phone and switching back on and the problem is still happening, can you please help? Thank you
11-04-2024 11:20 AM
Hi @CD6864
Are you in the UK?
Have you recently made any account changes or ordered a new SIM card?
Thanks 🙂
11-04-2024 11:36 AM
Hi Leanne, I'm in the UK, no changes to my SIM or account. Thank you
11-04-2024 11:42 AM
Thanks @CD6864
Is the SIM pay as you go or pay monthly?
Does this show no signal in more than one area?
Are you able to try the SIM card in another phone to see if you get signal?
11-04-2024 11:46 AM
My phone is pay monthly. My husband is an EE customer and he has service, I can't try his sim as he's currently at work
11-04-2024 11:48 AM
Thanks @CD6864
How long have you had no service?
Have you been in any other areas to see if you get signal?
11-04-2024 12:05 PM
The problem is intermittent, it started a couple of weeks ago. I was in a different area this morning and was able to make a call. Its currently showing Ee, I'm calling my mobile from my work phone and it says the number is currently unavailable. I've now checked and its Emergency Calls only again!
11-04-2024 12:06 PM
I see, thank you @CD6864
Do we have any known problems showing for your area on the EE Coverage & Network Status Checker if you enter your postcode and select 'check status'?
11-04-2024 12:26 PM
There are no problems showing in my area
11-04-2024 01:35 PM
Thanks for checking @CD6864
It would be good if you could try the SIM card in another device to see if the no signal follows the SIM or the phone to see what would be needed to get this sorted for you.
Are you near an EE Store you could visit and try this?
Leanne 🙂
