Re: Apply to have a mobile phone mast installed
AdminChappy
Hi, we are the Estate Department of a development of 93 Flats in a Grade 2 listed building set in 22 Acres of Woodland set on the edge of the Severn Estuary. Mobile reception is poor and I note the the Ofcom map identifies the EE Coverage in this area as "Some Problems" for both Data and voice.
We are also looking at different ways to raise revenue to offset the increasing costs associated with running this historic building and would consider a Mobile Phone mast set into the grounds. How do we start the process?
Thanks,
Neil
Leanne_T
Hi @AdminChappy
I've sent you a private message for some extra details.
