Pixel 7 and 5G
paulrcurtis
I have a Google Pixel 7, a few months old, purchased from John Lewis. I have an up to date SIM card. My plan is 12M SIM Essential Plan.
I don't get 5G even where I should. I am sure the phone is capable of getting 5G.
Is this a setting issue, or do I need to play more for an upgraded SIM plan please?
28 REPLIES 28
Katie_J
I'd definitely recommend giving them another call @paulrcurtis.
It would be great if you could also keep us updated on this thread.
Katie 🙂
Just wanted to add 1 more user here with the same issue.
Pixel 7 and never received a 5G signal. I've been to enough big cities (Newcastle, Leeds, York, London) and never had 5G access. Tried phoning EE over a year ago and was told it should be working and probably just a reception issue. I know it isn't.
Linzi_H
Hi @DanB1979
Welcome to the community!
If you are a Pay Monthly customer, have a compatible phone and plan, and are within a 5G area then I can't understand why you've never seen a 5G connection yet.
It sounds like this has been ongoing, so I would suggest to contact us again so we can review this with you further.
Linzi
Technaudio
There should be a setting in the phone to select which type of network you want to use, however, somehow EE disable this setting. I don't know how they do this, I buy my phones direct from Google and that menu disappears from my phone when it's on EE, with a Vodafone SIM, the menu IS there!
There is another way though...
On the Dialler dial *#*#4636#*#* this opens a 'secret' settings screen.
Go to Phone information...
Near the bottom there is 'Set preferred network type' with a drop down arrow.
Now you should be able to select from a list of network types. Don't worry too much about what they all are, basically if it says NR its 5G
In all honesty though, in my experience, 5G is pretty rubbish, so I have it turned off most of the time.
There has only been a handful of times when 5G has been better than 4G, most of the time 5G is actually slower than 4G! This is because currently, most of the the 5G networks aren't 'true' 5G, they piggyback onto the 4G network!
Slow data speeds are caused by insufficient capacity on the serving site/sector for the usage being demanded. SA/NSA mode is a different issue.
Just realised the screenshots I posted had my phone number on them, they seem to have been deleted now. Whoops!
Here's it again (without my number!)
Further to this, I've been to Croatia and had 5G everywhere, back to the UK and back to 4G (regardless of location).
Also the guy sat next to me on EE (different phone) has 5G
Peter_W
Welcome back to the Community, @DanB1979.
Have you ever had a chance to test your EE SIM in a different handset to see if this is able to pick up 5G from there?
With a query like this it's always best to make sure we can have an awareness of where the issue is originating from.
Peter
Sorry for lates response, missed this!
I haven't a handset easily available to try but it is worth a test.
The thing is though, if the sim card was the issue then it wouldn't have worked out in Croatia
