No signal UK
Nicw12
Good morning!  I strangely have no signal this morning but others in my office on EE do?  I can't activate wifi calling either so can't phone EE to see what the issue is?  Does anyone have any suggestions on how to remedy this?  I have had a look and there doesn't appear to be a chat function on the EE website for me to use?
Thanks in advance
Leanne_T
Hi @Nicw12
Thanks for coming here.
Have you restarted your phone?
Is this in the one area that you have no signal showing?
Thanks 🙂
Leanne 🙂
What's stopping you from activating WiFi-calling?
The other troubleshooting would be to do a 2way SIM-swap with a working phone, and see if the problem follows your SIM or remains with your phone.
Nicw12
Yeah I did restart and there is reception in the area, turns out EE deactivated my sim for some reason?! Sorted now thanks
Wifi calling is not working either, and I don’t have another SIM to try but it turns out that EE had deactivated my SIM in error - they are sending out a new message  one
Christopher_G
Sorry to hear that happened, @Nicw12.
Glad you're up and running.
