No service
Mez88
This has happened the past half an hour I'm unable to make any calls can't even ring 150
8 REPLIES 8
This may be a local coverage issue which you can check using the "check status" option on https://coverage.ee.co.uk/coverage/ee
If not, you can check for account-specific issues by calling 0800 0798586 from another phone.
Kirigaya_Kazuto
Star Contributor
Star Contributor
Same issue - having to use my second sim on RWG mobile (NVMO on EE) to ring 150 - they're being inendated with calls/tweets
See their twitter page, full of tweets of people have the same issue
Something going odd with the SIM cards it seems, as the coverage checker reports no issues
Tweets with replies by EE (@EE) / Twitter
Christopher_G
Hi @Mez88
Is it working better now? Could you try restarting your phone, if not?
All is fixed today, no idea what happened, any idea @Christopher_G
My service came back slowly around 8pm, firstly it connected to EDGE, the 3G for about 30 minutes, then 4G
Meanwhile my RWG Mobile sim had 4G, so it couldn't have been a mast issue as it also runs on EE
Christopher_G
I really don't know, @Kirigaya_Kazuto. It sounds like you've lost the connection to the network somehow. I'm glad you're back up and running. 🙂
Yeah services resumed few hours after last night, I tried restarting my phone a few times and reset sim etc and didn't work. God knows what happened isn't good that I missed an important phone call though 👎
Christopher_G
Sorry about the inconvenience, @Mez88.
There could be a few reasons why this happened. I'm glad it's working now for you though.
