26-10-2024 08:23 AM
26-10-2024 02:04 PM
Restarted the router, which didn't work, and forgot both WiFi (5g and 2.4) and still not working.
26-10-2024 02:16 PM
OK, thanks for trying, @Lesleyh123
I'm not sure why it isn't working for you. If you're a pay monthly contract customer, it may be worth going onto our live chat service, so they can check your account. You can access it through the 'help' section of the EE App.
26-10-2024 02:24 PM
Thanks Christopher
I'll try that 👍
26-10-2024 02:32 PM
The AI chat function just keeps going through Network issues and tells me to set up WiFi. Or it tells me to ring. It appears impossible to get it to put me through to a person 😞
26-10-2024 04:33 PM
Do you have another phone that you could give us a call from, @Lesleyh123?
26-10-2024 04:45 PM
No, sorry, that's the problem! We're both on EE, and both have Google Pixel phones (different models).
We can't contact Paul's unwell and elderly mum 350 miles away.
27-10-2024 09:44 AM
I understand your concern @Lesleyh123
Can you try to turn the WiFi Calling setting off on the phone and then try a restart again, before switching WiFi Calling back on to see if that helps to get you connected?
Michael
27-10-2024 04:46 PM
Thanks Michael, we will do when we're back home. Just got a text saying it's still down and taking longer than expected to fix. Let's hope it's soon.
28-10-2024 06:53 AM
Hi Michael,
I've tried that and WiFi calls are still not working. If we drive 6 or 7 miles to a local village everything works ok (ie normal network ) but not at home.
The network checker still says it's down too.
28-10-2024 01:18 PM
Good afternoon @Lesleyh123, thanks for giving that a try for us!
What happened when you tried enabling WiFi Calls?
Also if you look at the icons at the top of your screen, when this is enabled do you see an icon that looks like a WiFi symbol with a phone next to it?
This is what would usually indicate that it's using this option for your calls.
Peter
