on 15-01-2023 03:33 PM
I live in Cheshire and have lost connectivity on my mobile. It looks like there's a local outage. Internet connection unaffected.
on 15-01-2023 06:07 PM
Mobile data uses the same network signal as your voice calls, so please explain the symptoms you have.
To be able to use mobile data dictates that you must have a mobile network signal displayed - and therefore whatever issues you have, are likely caused by something other than a local outage.
