Is EE down due to the global it outage?
Scores62
I’m in East Devon - anyone else struggling with no service? Is it due to the global outage? Any idea when it will be back up?
thanks
If you've not done so already, try toggling flight mode to ensure your phone hasn't "dropped off" available coverage.
Use the "check service status" option on https://ee.co.uk/help/mobile-coverage-checker  in the first instance, to check for local service outages. A loss of coverage will remove the ability to make/receive calls, send/receive texts or use mobile data.
If you're in the UK and have a WiFi connection, you can use WiFi-calling to keep using your phone as normal without needing network coverage.
Thanks I’ll give that a go
Sent from Outlook for iOS<>
