30-01-2024 08:44 PM
I keep getting a message saying no Internet access whenever I'm out. Never been a problem till recently. Use a few parking apps and each time I go to use one I'm given this message. What can I do?
30-01-2024 10:23 PM
Can you be specific on what you mean by "recently"? Where, roughly in the UK, are you?
Are you able to use other internet-based functions on your phone when this happens?
31-01-2024 08:28 AM
It's been in the last month. I live in Essex. To be honest I haven't tried getting any other internet based functions while I've been out. I know there isn't a problem with the actual Apps as they work at home. I don't do email on my phone but I do WhatsApp so will try sending a message while I'm out today. Thank you for trying to help
31-01-2024 08:39 AM
Hi @lyndalupin
Thanks for coming here.
Do you have signal showing when you get this message?
Do you data remaining from your allowance?
31-01-2024 08:45 AM
I know I have enough data and I have no problem getting the parking aps from home because I have started to use the pre-booking system due to having this problem when I'm out. Sorry I'm a bit of a dinosaur when it comes to technology - what signal and where do I look for it? All I get is a red message on the screen saying No Internet Access. Thank you for trying to help
31-01-2024 08:55 AM
31-01-2024 09:12 AM
Samsung Galaxy A53 5G
31-01-2024 09:18 AM
Thanks @lyndalupin
If you go into Settings then Apps, select the parking apps are they set up to use mobile data?
31-01-2024 09:37 AM
under Mobile data it's got No data used. Also the Remove permissions if app is unused is on? not sure if that makes any difference
31-01-2024 09:49 AM
Thanks @lyndalupin
Can you try using other apps when you are away from home and not connected to WiFi this will help us know if this is affecting all data usage?
