17-11-2022 04:38 PM
Hello All. (hopefully someone from EE)
For the last few days when I call a number from my contacts I get a message saying "You have dialled an incorrect number" it can do this 2 or 3 times and then it connects. It is every number I call so its not one particular number. I have powered off my phone, taken the sim card out and gave it a clean, inserted it back in and powered on the phone. Everything seems fine but then when I call a number the same things happen. Can you please let me know if there is a network issue or if it has anything to do with a recent update on my Galaxy A71.
17-11-2022 05:53 PM
Does it make any difference if you dial the call manually as opposed to using your contacts?
17-11-2022 05:58 PM
I've mostly called contacts but 2 calls I've made by dialing the number it has also done the same.
17-11-2022 10:00 PM
Is nobody else having this issue?
18-11-2022 07:28 AM
Hi @Manny72
Thanks for coming here.
Can you receive calls OK?
Are you able to try the SIM card in another phone to see if the same happens?
18-11-2022 07:55 AM
Yes i can receive calls ok. I'll try it in another phone later. Seems to be happening afer a recent update on my phone so that may be the cause.
18-11-2022 07:57 AM
Let me know how you get on @Manny72
Leanne 🙂
