Hereford hr2
blacktaffy2003
just purchased an extra 20gb of data but download speed around 2mb on 4g, EE says there is no problem in the area. Clearly there is as I have reached around 100mb in the past.
Sounds like you've used the "check status" option on the webtool to search for known issues in a locality.
I'd recommend now using "report a problem" to provide further details for closer checks.
12 REPLIES 12
blacktaffy2003
Katie_B
Hi @blacktaffy2003
Thanks for getting back to us.
Are you experiencing this with your standard data allowance as well?
Katie
Yes
Katie_B
Thanks for confirming @blacktaffy2003
Are you aware of others experiencing this?
Katie
No
Leanne_T
Thanks @blacktaffy2003
Do you get service in other areas? Do you have a pay as you go or pay monthly account?
Also. are you able to try the SIM in another device to see if you get signal?
This would let us know if the SIM or phone may be causing this, if no problems are showing for the area.
Leanne 🙂
Just run a speedtest, download 3.68 over 4g.
Last week I got 45mb in another location.
Pay monthly plan
Leanne_T
Thanks very much @blacktaffy2003
Have you reported the slow data on the service status checker? If nothing was showing as reported, you can select the 'still having problems' option then 'report a problem' once the area has been looked into we will send you an update.
Or, please give us a call and the team will get this looked into for you.
Thanks 🙂
