Network
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
15-08-2024 09:04 AM
Hi
2 things
EE doesn’t seem to recognise my postcode which is Hereford HR1 postcode
the network seems to be down? Only emergency calls on my mobile
anyone experiencing this?
thanks
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
15-08-2024 03:38 PM
Many thanks Alex
just back from the EE shop
removed the old sim
put back the EE sim
works as good as new!😀
Am not really well versed in such stuff but the person at Hereford shop was brilliant
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
15-08-2024 11:16 AM - edited 15-08-2024 11:16 AM
Hi @SB232,
Welcome to the EE Community 🙂
I am sorry to hear you are having some network issue this morning and have had an issue using the checker. If you login on the page below to our check your service status, it will check for any issues on your registered home postcode automatically, does that check work ok and is on the same postcode you were having an issue checking?
Service status in your area (ee.co.uk)
Alex
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
15-08-2024 01:57 PM
Hi Alex
the link you sent shows network is ok
however my phone has “emergency calls only”
it seems to be right acronyms hereford city centre
is it just a matter of being patient and Hope this rights itself say by tomorrow
every time I try to phone what I get is “cellular network is not available connect to wireless network”
ihope this gives you an idea of what may be wrong?
thanks for your response
satish
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
15-08-2024 02:10 PM
@SB232 If it is showing as ok on your status checker, it does mean we are not aware of any issues in the area, the issue could potentially be phone or SIM related.
Are you with anyone else on EE at the moment to see if there signal is effected also? Have you restarted your phone since the issue started? And what model of phone is it you are using please?
Alex
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
15-08-2024 02:37 PM
Thanks Alex
1. my internet provider is BT
2. have restarted the phone. It’s android Honor 90 lite model
3. I was previously with 3 so the 3 SIM card is still in the phone
will go to EE shop and have it removed tomorrow and I hope it works
thanks for now
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
15-08-2024 03:24 PM
Ah I see, so you have both your old 3 SIM in the phone and the EE SIM is that right? If the EE SIM was working fine with it previously that should not be causing an issue.
If you go to Settings> Mobile Networks> Mobile data> Under the EE SIM select Network Provider>Turn off automatic and the phone will do a search for available networks, is the EE network found when doing a manual search?
Alex
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
15-08-2024 03:38 PM
Many thanks Alex
removed the old sim
put back the EE sim
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
15-08-2024 03:48 PM
It's great to hear that they got it sorted for you in store @SB232
Thanks for getting back to me and letting me know.
If you need any further help don't hesitate to reach out to us again 🙂
Alex
- EE Roaming Data Speeds Slow but Fast in UK. APN or Roaming Issue? in Mobile Data
- Frequent disconnection from mobile network in Mobile Network discussions
- keeping ee number from 24 month contract to 1 month sim contract in SIM cards & Porting
- Not receiving OTP texts in Mobile Services
- Network issues in Mobile Network discussions
