Gaming speeds in my area
Plutomaine
 with my new array on EE mobile 5G finally getting the latency and upload times I need for gaming
[mod edit: removed personal details and changed title]
I've got one set of biquads and two offset log differentials. Feeding into
my 4 x 4 router equipped with a EE sim.
Nearest EE mast 2 miles away.
Northerner
Hi @Plutomaine
Hope it is consistent for you.
Lesley_W
Hi @Plutomaine
Lovely stuff, thanks for sharing!
Lesley
Plutomaine
To add to this. It proves that no matter where you are so long should have decent directional antenna. Which incidentally those two long periodic antennas I bought from China £14 each.  You can get some really fast downloads and good uploads. Which improves latency. Feeding into a decent two to two memo router.
My original configuration consisting of these two antenna 45 degrees offset feeding into a tp link MR600, which you can purchase used for about £60 off eBay. Will achieve uploads well in excessive 200 and downloads of about 20.
Plutomaine
