EE 4G dreadful at Clapham Junction
DJW-20
Just been out through clapham today, twice. Took 2 speedtests at different times on the platforms.
This was it at 09:32
And at 16:38, not even a speedtest would work, let alone an imessage send.
Is anyone else having this sort of experience there? And more importantly, does anyone have a crystal ball and could tell me if EE are planning an upgrade here? It seems like it needs one. I was also under the impression they were putting a DAS there
I am NOT an EE staff member, but I'm still happy to help! I cannot access your accounts
24m EE essentials Max
BT 900mbts FTTP
6 REPLIES 6
Out of interest, did you make a note of which bands/carriers you were using?
Northerner
Hi @DJW-20
Are you on EE PAYG or pay monthly contract.
Looks like you're connected to 4G only.
Try restarting your device.
DJW-20
B7
BT 900mbts FTTP
DJW-20
PM
PAYM on an essentials max plan. My device doesn’t support 5G but it still falls below what is expected from EE 4g.
When I upgrade in September/October we can retest that
Performed a manual roam when there, that has basically the same effect
BT 900mbts FTTP
Northerner
Hi @DJW-20
What device as it must be old to not have a 5G radio. If you're on 4G only you maybe limited to certain frequencies hence the speed.
This is not a scenario caused by the user being on 4G, and thus 5G being the fix
A 4G-device is capable of speeds much greater than quoted here.
