Calls drop after two seconds but inter calls are ok
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
19-06-2024 09:27 AM
Hi all I a S10 that been working fine, with only one small issues that was fix last year as soon as I called up about it. Namely calls going to answer phone.
Any now the issues I have is very time I make or get a call it drop after two seconds. If I let ring it just keep ring.
If I Internet call or an app with data turned on it works fine.
Resetting the phone will fix the issue for a bit but it does come back. I have seen if been working and drive say to the shop it will stop. So it might a issues switching towers any got any idea on how to fix this?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
19-06-2024 11:45 AM
Hi @Andrewgw
Thanks for coming to the community 🙂
Does this happen in more than one location?
Is your software on the S10 up to date?
Speak soon.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
19-06-2024 12:46 PM
Does the use of WiFi-calling make any difference? If literally 100% of calls are affected, this tends to point at a device fault.
