Aberchirder Scotland coverage issues
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
06-04-2023 07:39 AM
Anyone else having issues in the Aberchirder ( Foggie) area, the coverage says
"You'll get excellent coverage indoors and outdoors on your Samsung Galaxy Xcover 5 Ent."
I look at the coverage map and that says the same
Yet im only getting 1 bar, i have WIFI calling setup and 30mbps wifi speed
I constantly get issues with calls, people not being able to hear me, and resorting to walking outside to the edge of my property in direct eyesight of the mast and still only get 1-2 bars, even with wifi calling on still getting issues with calls one day then the next day its fine
when sat in my house just now i see the signal strength this -112 dBm 26 asu
I regularly get email updates to say there are issues been worked on near my home
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
06-04-2023 10:01 AM
Hi there @gavmidd
Welcome to the EE Community.
Does the Network Status Checker report any problems for the area?
If no problems are reported (after selecting the 'check status' option), please tap 'report a problem' so our network team can investigate and keep you updated.
Thanks.
Leanne
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
06-04-2023 10:56 AM
Our engineers have fixed a problem here. It should all be working again now. If you're still experiencing problems, let us know.
Or try these quick fixesEmail of issue fixed
Thu, 6 Apr at 07:12
this issue has been going on for a few months now
Last time i had the same set of fixed emails is below
Report a problem
Thanks for reporting your service problem, a reference number is on it's way. We'll be in touch with an update within 48 hours.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
06-04-2023 11:02 AM
Thanks for reporting this @gavmidd
The team will get this looked into and keep you updated 🙂
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
06-04-2023 12:36 PM
Do you know any other EE users locally who have the same problems?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
08-04-2023 09:26 AM
Update Thursday 6th april 6pm
Network update: The problem you reported in AB54 7SJ has now been fixed, we recommend you restart your device. If you have already done this and are still having problems, please call us on 150. Your Report ID is 4382310. For information on how to improve your signal, click here
Issue still the same all day friday ( yesterday)
Signal strength right now -111dBm 29 asu
I would love to Know what the resolution fix they have done against these last few tickets, we are not getting to the bottom of this at all
I have even put the SIM card into slot 2 of my phone but still no improvement
Would a replacement SIM card rule anything out?
Would EE resending any settings help?
All software up to date
service provider software
SAOMC_SM_G525F_OXM_BTU_13_0007
BTU/BTU/BTU/EEX/BTU/
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
08-04-2023 09:40 AM
Hi @gavmidd
Thanks for your patience with this. If you speak to our Technical Support team, they may be able to give you some more information on this.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
08-04-2023 09:47 AM
Does your phone work as expected in other locations? The network settings would affect your service in all areas - equally a comparison with other EE users in this same location would be a good test of whether this is network-related or not.
Are you able to identify the serving EARFCN or LTE-Band in use? Also how long has this been a problem?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
08-04-2023 10:12 AM
EARFCN 1617
Been a problem for months
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
08-04-2023 10:29 AM
As I suspected, your phone is using 4G-Band 3 and there is Band-20 service on many serving sites around that area.
There's therefore a few variables at play here, and I've experienced some similar symptoms myself over the past year in particular scenarios.
I have my suspicions as to the underlying cause, and it may partly be a waiting game - but I would recommend you persist with reporting this via the CS route. You'll likely need to deal with a secondary area of support in order to get the required level of expertise - and this may need some patience & persistence.
