on pay as you go , like some data info
martyn858
there is data addon listed on the app
500mb for 7 days for £
but the 150mb for £2.00 does not say how long that it lasts, do anyone  know how long the 150mb add on last, it a day or until you have used it up maybe no time limit
They both last 7 days:Capture.JPG
10 REPLIES 10
ee also do a  data only sim 200mb for £1 for 30days, or until its used up,  is that not a better deal, my phone can take two sims
Do they? I don't see it in the PAYG tariffs.
It would be if you can get it but how?
Best Data Only SIM Plans | Preloaded Data SIMs | EE Shop
he is the web link to the site i found it on,
would this work
regards
354-
Star Contributor
Star Contributor
You posted no web link.
Which EE shop? There are 2 separate ones, the normal online EE Shop & the retail high St. stores.
thats them   yes
cheaper price but also lasts longer  ,  any better then the other add-on
That involves buying a new with a new no. The OP was enquiring about add-ons to an existing SIM.
Only you can weigh it up, depending on how much you use over time.
  • The 150 MB for £2 works out at 21 MB / day.
  • The 200 MB for £1 works out at 7 MB / day.
