01-10-2024 11:33 PM
I have a Data only sim used in a router. Has anyone encountered not been able to access certain websites using EE? I can't access my online banking, torrent sites and the list goes on. Is this a common problem?
02-10-2024 12:44 PM
Good afternoon @cdadelacy.
Welcome to the EE Community 😊
Could you please let us know a bit more about what's happening when you try to access these sites? For example do you see any errors?
Also what bank is it you're trying to access here?
Peter
02-10-2024 01:44 PM
Do you have any specific examples of sites you have issues with?
02-10-2024 10:43 PM
02-10-2024 10:44 PM
02-10-2024 10:47 PM
I get the following and it only happens when i use my EE sim. When i go back to my old network it connects fine
02-10-2024 10:48 PM
03-10-2024 04:08 PM
Hi @cdadelacy
Thanks for sending those across.
It's worth checking your content lock is turned off if you are having trouble with some sites. You can see more about that on our How Do I Turn On Parental Controls on My Device? | page.
What error are you getting with your online banking?
Lesley
03-10-2024 09:34 PM
No screenshots there but PirateBay has been banned by Court Order, which should be obeyed by all big networks.
