09-08-2025 03:27 PM
I've noticed in the last two weeks that I can't access certain apps like ChatGPT and Snapchat because it's flagging up that the server is using the wrong SSL certificate.
It works perfectly via WiFi and if I use a VPN on cellular, it works fine also. I have restarted my phone twice and it's not made any difference. My handset is the Sony Xperia 1V but there was no software update prior to the issues and other networks aren't having this issue.
09-08-2025 03:55 PM
Hi @Isildore
Have you tried a different browser.
10-08-2025 07:08 PM
With ChatGPT, it is the same either in Firefox or Edge as well as the app. Snapchat was just the app.
11-08-2025 09:29 AM
Thanks for coming to the community @Isildore
Are you able to try the SIM card in another device to see if you can access the apps without getting this message?
This will help us to know what could be causing this for you 🙂
