ftp only working with vpn on ee
rachel1223
Hello
I have an frp server with a shared folder On ee data I can only access it through a vpn with other mobile carrier it works fine Why are ee blocking ftp?
1 ACCEPTED SOLUTION
Try changing your Access Point Name settings on your Samsung to use IPv4 for the APN Protocol. Under Connections > Mobile networks > Access Point Names.
Create a new APN Profile, copying the details from the default "internet" and just changing the "APN Protocol" setting to IPv4 instead of IPv4/IPv6.
You can also find a guide on the APN Settings here in case you get stuck: https://community.ee.co.uk/t5/Mobile-Data/EE-APN-Settings-Where-to-find-them/td-p/1145404
19 REPLIES 19
Matt_124
What kind of device are you using your EE SIM in?
samsung s23+
works ok with  3 mobile sim
Where is this FTP server? On your own LAN or remote?
pc server on own lan
What router's controlling your LAN?
now tv
interesting working ok using SPUSU payg sim I assumed using ee !!
@rachel1223 , the router is not your TV, please give us the name of your router as asked above.
Why do you not want to use VPN? It is safer than not using it, if it works with VPN, what is your problem?
