26-10-2022 09:44 PM
Hello
Ive been having speeds below 100Mbps on a 5G connection… is there an issue here ?
26-10-2022 10:42 PM
How long have you been having this issue? Is it at all times of day/night?
You can check for known area issues by selecting "check status" on the coverage tool - I suspect you've clicked "check coverage" already.
27-10-2022 05:55 PM
Yeah I posted the screenshot but it’s not showing up. It’s saying ‘You'll get excellent coverage indoors and outdoors on your iPhone 14 Pro.’
27-10-2022 06:01 PM
Hi @IJDS16,
What is reported if to select the 'check status', rather than 'check coverage' option?
