08-08-2026 11:31 AM
I ordered my SIM card to join EE on the 4th and got it on the 5th (Wednesday). One of the options I chose was to move my number over from Tesco, and I gave EE my PAC code on Tuesday with the order. I understand this takes a while, but is there a way to check that it's being processed? I have a call I'm expecting on the 13th and would hate to miss it because I didn't set up PAC correctly.
I have tried calling 150, but I am unable to speak to anyone. I just get sent text messages to give them my PAC again but I know doing it multiple times can slow down the process. I cannot work out how to speak with anyone. Is it possible to talk to someone via 150 or is there a different number I should call?
Thank you for any help you can provide.
08-08-2026 09:05 PM
@rkelly1 wrote:Once you have activated the sim, the port would normally take place the following day.
Alas not quite, number ports do not take place on weekends or bank holidays.
Your new EE SIM will have a temporary number assigned when you first receive it. If a PAC was supplied as part of the order, that will be submitted when you first activate the new SIM onto EE's network.
A port-in date will be set then, usually the following working day. This assumes activation during normal working hours - if during the evening, add an extra working day to these timescales.
Absolutely call EE-CS if you want account-specific advice - they have access to your individual account. Worst case scenario here, is your PAC is submitted before end-of-day on Monday 10th, for port-in on Tuesday 11th
08-08-2026 12:04 PM
Once you have activated the sim, the port would normally take place the following day. If you have inserted the sim and have not received an update to advise when the number will be transferred, I would absolutely call 150 to check if the request has been processed, or so they can do it for you
08-08-2026 01:53 PM
Hi @MissQueenie
Our mobile guides will help you get this sorted if you get in touch.
For ways to contact us from the EE SIM or another phone, please see our Contact us page.
08-08-2026 09:05 PM
