Reolink Camera
Cerihepp
Hi ,
can anyone help me with my camera issue . I have purchased a data sim with prepaid 120gb and inserted it into Reolink Camera but camera keeps saying I need to activate Sim . I’ve called help and they say it’s already activated . I’m now stumped !
8 REPLIES 8
Northerner
Hi @Cerihepp
The SIM/network may not be compatible with your camera. Have you checked on the Reolink website/support.
Hi ,
Yes I checked with them and they said that an EE data only sim was needed
hence why I purchased a 120 GB data sim .
But I’m getting same message I got when I tried to use an ID mobile monthly
sim
Don’t really know where to go now and how to sort it . Have i purchased an
incorrect sim again ?
Ceri
Has the camera said this from when you 1st inserted the SIM as new or has it just suddenly happened?
Hi ive tried two different sims in a new camera and it’s said that both
sims need to be activated but Ive spoken to both providers customer support
and they were both activated sims
Ceri
Yes this is all it has said
with this SIM card and with a previous SIM card
it says -
not registered on network , please activate SIM card
ceri
I was asking whether the SIM was new when you inserted it, not the camera.
Are you in UK?
Hi yes I’m in the Uk and both sims were brand new , not put into another device
ceri
Leanne_T
Hi there @Cerihepp
Thanks for coming here 🙂
Are you able to try the SIM card in another device to see if you get signal?
The SIM card should be registered for you, if this is not a replacement and show a EE signal in an unlocked device.
