09-11-2022 07:44 AM
Hi, I’ve just returned from a 3 day trip abroad. On the 3rd day I noticed that when not on WiFi, I was literally unable to connect to WhatApp at all and Maps would take about 5 minutes to load even the most basic directions. 4G was virtually unusable despite showing good coverage (3 or 4bars)?
I am confused why this may have happened?
09-11-2022 08:21 AM
@aswils It could be the local network there has/had issues in that area.
09-11-2022 11:08 AM
Hi, thanks for the reply. I think is was more specific to me as others with me didn’t have the same issue.
09-11-2022 11:12 AM
Hi @aswils,
Were the others connected to the same roaming network?
09-11-2022
11:17 AM
- last edited on
09-11-2022
11:28 AM
DanielPA
I’m not sure, to be honest. Another reason I thought it may be more specific was at a football match the previous evening, I was getting zero 4-G coverage when all people around me were using their phones and browsing with no issues.
09-11-2022 11:48 AM
Hi @aswils,
It could be that the others were connected to another network that wasn't affected by a local network issue.
If it happens again when you're travelling, I'd recommend performing a manual network search.
19-11-2022 02:07 PM
do you pay the £2/day or did they give you a free roaming add-on?
I have the latter and have found that they restrict the bandwidth to the extent that's is not worth having.
19-11-2022 02:09 PM
why don't you guys just admit that you restrict roaming bandwidth.
It's also not possible to manually connect to a network that isn't your partner. Why is that?
21-11-2022 07:43 AM
I have the same question..."why don't you guys just admit that you restrict roaming bandwidth."
