on 18-03-2025 12:51 PM
Hi EE
I didn’t activate roaming before I got to the US. I have ad one that allow me to make international calls and access my mins, texts and data but it isn’t working.
I suspect this is because I didn’t activate roaming. How can I contact EE online? Or notify them in abroad by email. I do not have access to a phone to call we. I can only contact you from online. Please help.
kind regards
Luke
18-03-2025 12:56 PM - edited 18-03-2025 12:56 PM
You call EE on the freephone number +44 800 956 6000 using a free calling app such as Skype on a WiFi Connection.
EE do not use email to communicate as it is too slow to resolve issues.
on 18-03-2025 01:51 PM
