11-02-2023 09:21 PM
It says on the website that I have all of my mobile data available but when I turn mobile data on it doesn't work. Anyone know why?
18-07-2023 10:33 PM
Ive just changed from BT to EE. I transferred my old BT number to EE as well and I’m doing a pay as you go allowance. Everything is working fine (texts etc) except from my mobile data. My 4G turns on and shows in the top right corner but when I go to use it, it doesn’t actually work and i’m unable to connect to anything. I’m using an iphone 11 pro max. any advice??? Thanks
19-07-2023 08:24 AM
19-07-2023 08:28 AM
Yes i’ve restarted my phone multiple times.
thanks,
Ellie
19-07-2023 08:39 AM
Hi @elliemaech,
If you go to Settings > General > About, are there any carrier settings updates available?
19-07-2023 08:55 AM
there doesn’t seem to be any updates available but it does say ‘network provider locked’. Could this be something to do with it?
19-07-2023 09:07 AM
Hi @elliemaech,
If your handset is locked to BT you may need to contact them to unlock it.
Just to check, is your phone definitley working for calls and texts? (Not including iMessage, WhatsApp etc. which can be sent over WiFi)
19-07-2023 09:57 AM
I just contacted BT and they said my SIM is locked to EE as i’ve now put the EE SIM in and that you can sort this.
Ive just double checked and nothing is working without wifi (texts,phone calls) etc
Thanks, Ellie
19-07-2023 09:57 AM
Call BT on 0800 800 150 and ask them to unlock your phone. How old is your phone? All phones after 2021 should be unlocked anyway.
Thanks,
Alex
19-07-2023 10:15 AM
Ive called BT and they’ve said that because I now have the EE SIM in my phone, you should be able to unlock it for me. They cant do anything now as I no longer am with BT.
19-07-2023 11:04 AM
