on 02-01-2025 05:59 AM
Hi all.
So moved from bt tp ee due to contract renewal , and was told it had to be done basically. Internet working fine although had an issues with Ethernet slow to activate, but was sorted with help from the community. Now I have a mobile data speed question .
I had a sim only when was on bt and it cost me the same as what i am paying for the sim om ee now, which all good . The issue i have is that the new card is limited to the 10mbps limit , and the bt one was not limited speeds at all .
So basically to get a 5g speed at all I would assume I would have to contact EE and upgrade the sim plan. Which in turn would cost more money . As this was not my choice and I was ported from bt to ee am I wrong I should be getting the same as I was getting before in speed for what I was paying , as it was not my choice to move and why should it cost me more if it was not my choice . Thank you
20-07-2025 10:23 PM - edited 20-07-2025 10:32 PM
@Luckyescape45 you really do not want to publicise your mobile on this public forum, suggest you edit your post before the scambots get to it.
But reported just in case.
on 20-07-2025 10:30 PM
Thanks!!!
