Mobile Data not showing Sim
abbiebowles2403
My IPad mobile data has disappeared. I have scanned the QR code and also put the details manually and it still isn’t working and says to contact network provider. Worked last night. Iv tried replacing the sim and restarting the iPad too still no luck.
8 REPLIES 8
Katie_J
Good morning @abbiebowles2403.
Are you able to text AL to 150 from your iPad?
Katie
No saying not delivered
Sent from my iPhone
No this states not delivered
@abbiebowles2403   You can not send text messages from an iPad.    You can however use THIS  to see what data allowance you do have
This is not the problem I have.
Sent from my iPhone
James_B
EE Community Manager
Are you trying to activate a new eSIM on your iPad @abbiebowles2403?
If you are, you'll need to call Customer Care to authorise the SIM swap.
Yes I have tried to as an option to try and fix the problem. What is the best number to call?
Sent from my iPhone
Hi @abbiebowles2403,
If you have an EE phone, you can call 150. If not, please call 07953 966 150.
