Iphone messages green not blue?
richsteels
I have an EE esim in my Iphone 11 but for some reason it will not allow me to send I-messages, (blue) only text messages (green) does anyone know why?
@richsteels  are you connected to Wi-Fi or cellular data ?   Are you sending these messages to another iPhone ?   Have you set up iMessage?    If on cellular data do you have any data allowance?   Is this just to one iPhone or all iPhones ?
Hi
Yes connected to wi-fi and cellular data I can only send text.
Yes, sending to other I-phones on wifi networks
Yes, I have lots of data
Yes to all iphones
Not sure about setting up Imessage?
I am using the EE sim as an E-sim. My other physical sim works fine on i-phone i-messages but when I switch to EE I do not have I-messages
James_B
EE Community Manager
Hi @richsteels,
You may need to tweak your settings to allow both of your SIMs to use iMessage. Does this Apple Support Article help - Using Dual SIM with an eSIM – Apple Support (UK)?
