Excessive data usage, not in line with phone
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
15-12-2023 08:22 PM
Hello,
I've recently switched to EE and everything has been good so far, except from yesterday when I got an 80% warning for data. It was at this point I turned data off on my phone.
This morning I got a message at 2am saying I had used 100% of my data.
I checked my phone (data was STILL off) and found the following graph on data usage;
clearly showing nowhere near ees stated value, as well as clearly showing the point at which I turned data off by the flat line.
I called EE on 150 and the response I got was that the most used app was Reddit and was told I would need to get gifted data from someone else on the plan.
I never had any such data discrepancies when on Plusnet, and am baffled by the 1.6GB used overnight after I switched data off in response to the 80% warning (as shown by the data graph).
Attached also are the messages received 9hrs apart.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
16-12-2023 08:44 AM
Hi and welcome to the community, @Hbege
When is your bill date (the day the data renews)? The warnings aren't quite real-time, but as close as we can get to it. It's possible that the data was used before you turned off the mobile data.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
16-12-2023 09:45 PM
Billing is 25th to 25th, SIM wasn't put in until December 2nd. Never had any discrepancies between plusnets accounting and my phone in 4 years, switch to EE and suddenly I'm using over 200% more data than the phone reports.
If the data was used before I turned it off (IE before the 80% warning), shouldn't I have gotten both warnings at the same time?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
17-12-2023 08:26 AM
OK, thanks @Hbege
It's difficult to say what has caused this. I can only suggest discussing this with our technical support team again.
- Complain in Mobile Network discussions
- Not being traffic managed, despite going over 600GB on my unlimited data plan? in Mobile Data
- New to EE - porting my number over from 3 in SIM cards & Porting
- No service in Singapore and New Zealand in Roaming
- Unlimited Full Works mobile plan - roaming in Roaming
