Duplicate sim
EE1701
Hi all, I have a pay and go 4GEE mini Wifi device, also I use a EE mobile phone to top up the 4GEE mini Wifi, but to buy data every time, I have to take the sim out of the mini Wifi and put the sim into the phone, is there a way of duplicating my sim card so I can keep one sim in the mini wifi and the copy in the mobile phone, this way I can credit my mini without the rigmarole of changing the sim all the time?
Thanks for any advice.
No, you can only have one SIM per mobile number.
7 REPLIES 7
Look at http://add-on.ee.co.uk/purchase from a device connected to your mobile router by WiFi to see what data add-ons are available.
Thank you for you're reply Bristolian.
Thank you for you're reply XRaySpex, unfortunately your link to http://add-on.ee.co.uk/purchase does not work.
Christopher_G
Hi @EE1701
What happens when you go to the link? You need to be disconnected from WiFi for it to work fully.
Not if you're using a mobile router.
Christopher_G
Touché, @XRaySpeX 🙂
