Roaming
zobbit
I have just returned from a cruise and urgently needed to use my data and phone calls while in Cyprus (EU), Greece (EU) and Turkey (non-EU).  In the good old days you could buy a roaming pass BEFORE leaving.  Now you have to wait until you arrive in the country whereby (if you are lucky) you will get a text from EE welcoming you that country. It will also give you options for buying either a 24 hour pass or a 7 day pass.  What the text fails to explain is how to actually buy these passes. No links included. Sending various texts to 150 just resulted in duplicate A1-generated rubbish which was of no help.  I had to shell out £65 to access the ship's wifi.  Having been with EE and before that, T Mobile, for 20 plus years, I am now seriously looking for another provider.
The Welcome text on arrival in a country should contain a link to where you can buy the roaming pass.
Leanne_T
Hi @zobbit
Do you have a screenshot of the text you received? This should have included a link to purchase the roaming pass, or you can visit add-on.ee.co.uk to purchase a pass.
Schockwave
@zobbit , using your phone and data on a cruise will cost you money and is expensive, so unless you want to use a lot of wifi, not worth the money, in my opinion. The only time you can use your phone connected to network is when it is near land or port.
Indeed, and it's an inherent issue with cruise lines. You are a captive audience without any ability to choose alternative provision, so for certain services they will use that for their commercial benefit.
Spikey007
http://add-on.ee.co.uk/purchase
That's the link you needed. (Buy passes in top right hand corner). Spent ages looking for it, they did not make it straight forward.
Cheers,
Lewis.
