06-06-2023 07:12 PM
I have just purchased the £15 25GB monthly rolling data for my mini portable wifi hub.
When I check the allowances it is only showing 26GB not 50GB, has anyone had similar and knows what I should do.
Thank you.
06-06-2023 07:19 PM
Look in your online MyEE Add-ons for the other 25GB. Sometimes it doesn't kick in until have exhausted the normal ration.
06-06-2023 07:34 PM
Thank you for your response.
Definitely not showing in the add on’s, wondering if it is worth contacting customer care tomorrow or waiting for it to run out.
