13-10-2022 08:28 AM
How do I allow my child to use data to play a game but block them using extra data to the plan.
Im concerned they will run up a bill. At the moment it states that they are restricted and they are getting annoyed. Thank you
13-10-2022 10:49 AM
Hi @Kat_3344
Thanks for coming here.
Can they access other apps?
If you log into your My EE app, select the account settings (top right) then Settings and permissions, you can turn off Buy data and leave Use mobile data on, so they can use the data allowance.
Thanks.
13-10-2022 11:29 PM
Thanks for the info. Unfortunately it keeps erroring when I try to change to allow data
14-10-2022 09:10 AM
Could you try on the My EE desktop site please, @Kat_3344?
