09-10-2022 06:24 PM
I am the main account holder and the app and website won't let me share data with my kids.
There seems to be a technical fault but when I try to call the wait time is in excess of 40 mins.
Anyone else having the same issues?
09-10-2022 10:20 PM
Hello @INDIJET ,
Welcome to the community,
I suggest you try ringing first thing in the morning. Weekends tend to be more busy, as there probably are not as many staff working.
08-02-2023 01:42 AM
I have bern in a similar position. I can log into the app but can't share my data. I should have unlimited data but it is showing as 0.
08-02-2023 07:38 AM
Hi @EileenCJ
This is what our unlimited plan help page says:
'if you’re on a unlimited plan you can gift up to 100GB of data or 120GB if you’re on a 5G smart handset plan. This will be the first 100/120GB and any data usage will reduce your giftable allowance.'
It sounds like you may have used that giftable allowance.
09-02-2023 04:03 PM
09-02-2023 04:17 PM
I am the same,
I’m the main account holder with loads of available data. My son rang to see if I could gift him some as he needs to use maps to direct him for work and it will not load up… I get as far as gifting the data page and then it says try again later!
Hopefully it’ll all be restored soon as I’ve never had any problems before
09-02-2023 04:20 PM
Yeah I'm trying to gift data to my wife and getting the following error in the app, tried on the computer and the page won't load.
20-05-2023 12:28 AM
Agree, Rubbish service. Broken every month so far!
20-05-2023 12:37 AM
Yes, same frustrating problem every month!
20-05-2023 12:38 AM
No, the app is broken!
