4g not working
Sarah597
Hi I have a 4GEE sim and in my settings my phone is set to 4G as the preferred one but when I turn on my mobile data it is still using 3G. I am still on the same data pack as before so I tried to change it to a one that supports 4G but when I try I says no other packs are available and to use 4G I need a 4G sim. But I already have one.
7 REPLIES 7
Northerner
Hi @Sarah597
What device do you have? Doesn't it have 4G capacity?
Your phone will connect to the strongest signal. There could also be a local issue. You can check for issues here:
https://coverage.ee.co.uk/coverage/ee
Hi I have an iPhone 7 and my local signal is good for 4G. On the coverage website it says that my area has better signal with 4G than with 3G
James_B
EE Community Manager
Hi @Sarah597,
Did you move from T-Mobile or Orange to an EE 3G plan?
No I’m just on EE PAY AS YOU GO
James_B
Hi @Sarah597,
What is the name of your current pack?
It just says £20 data pack
James_B
Hi @Sarah597,
Please get in touch with Customer Care so a member of the team can take a quick look at your account.
They'll be happy to help. 🙂
