Wifi 2 4G
Meggzzymoo
Ive just received the EE wifi 2 4g dongle box and im wondering is it safe to leave plugged in constantly if we remove the battery? We will be using this as a main wifi source in an annex, thanks.
Alex_H
Hi @Meggzzymoo,
Welcome to the EE Community
Yes if you do plan to run the device off the mains continuously, it is recommend to remove the battery from the device, but it is safe to leave plugged in for continuous Wi-Fi connection.
Alex
Plugged into the mains or some USB device?
Into the mains via the charging cable it came with.
Alex_H
Hi @Meggzzymoo,
Alex
